3.9 diff on stock vette
Old Jun 10, 2009 | 03:01 AM
vetted's Avatar
Default 3.9 diff on stock vette
Hi, I was wondering how would a 3.9 differential upgrade suit an otherwisw stock 2000 auto C5. Is it worth it?
Regards
Old Jun 11, 2009 | 05:47 PM
Well, it will provide a great deal more torque multiplication than even the factory "performance" axle ratio. The car will feel like it picked up a lot of "GO1" from a standing start, and be much much preppier in slow streets around town.
Somewhere in the technical or general discussion topic areas, a long time ago, I added a very long discourse about axle ratios and the pros and cons. One point to think about is that there will be speeds where the stock car has more power: the 3.9 car has had to shift into second and the stock car is still in first, etc. Still, overall it will make the car faster feeling and a bit faster at the track.
It will also rev much much higher when cruising at any speed and get poorer gas mileage.
A 3.90 ratio is pretty extreme. If you go with a 3.42 you still have 10% more torque and about more than a quarter more than the standard axle ratio multiplication that the factory performance ratio.
Old Jun 12, 2009 | 02:07 PM
3.42s are very common swaps into A4 tranny C5 Corvettes. Lee is right in that a 3.90 is extreme for an A4. I do consider a 3.90 as a good replacement for a coupe or vert's 3.42.
Old Jun 14, 2009 | 03:07 AM
vetted's Avatar
I really appreciate the help available on this forum, especially Mr. Lee Willis.
i am in the process of ordering the 3.90 set up, however living in pakistan makes it difficult for me to fulfill the conditions of a core exchange so i will just order the ring and pinion set and have the gear ratios changed on my existing diff instead of buying the entire pumpkin. Any ideas if it would work.
nightmel
May 13, 2022 02:07 PM
MMperformance
Aug 4, 2008 09:05 PM
Fuzzy74
Apr 27, 2007 01:32 AM
myronp22
Aug 11, 2006 04:52 AM
raisinbran
Apr 4, 2006 02:25 AM
