2002 Z06 Oil Pressure
Old Jul 23, 2010 | 08:15 PM
corvette-1969's Avatar
Default 2002 Z06 Oil Pressure
I have a 2002 Z06 with 27,000 miles that I bought in December of 2009. Ichangedthe oil by draining and raising the back. Used a K&N filter with 6.5 quarts of 5W30W Mobile 1 oil. The car used to run at 40 psi with a Fram filter at normal operating temp and speed. Now the car runs at 50 to 55 psi at normal operating temp and speed. The only other change was to add a magnetic drain plug. I can not see how that would change oil pressure. Any comments on your normal oil pressure or possible cause of this change?
Thanks, Steve
Old Jul 23, 2010 | 09:39 PM
While a new K&N filter may very well increase oil pressure, the amount of increase is the key. What is the pressure when your oil is hot (>160F) and at idle? I believe 50-55 psi at speed is not high enough to be alarmed.
WHIPSrx7
Aug 2, 2006 06:16 PM
byedan1
Jun 1, 2006 12:30 AM
SLJ2137694
May 16, 2006 02:32 PM
Patterti
Feb 22, 2006 02:29 AM
Vet Head
Oct 31, 2005 02:17 PM
